Re: 6D canon
Op de fredmiranda forums is er een zekere Ralph Conway die de 6D eventjes getest heeft op Photokina. Dit waren zijn bevindingen over de autofocus:
The outer AF points worked very good (immediatelly reaction and accurate) on the well lit booth. Felt much better than 5D II ever did.
There was a dark "testcave" to check the center AF-point -3 EV capabilities. The target was so dark that I even was not able to see where I was pointing to. I just saw some kind of a more lit area pointed the center AF sensor to it and pushed the shutter release.
The result was blowing away my mind. The confirmation with 50mm 1.4 came immediatelly! The focus set perfect and I first could see what I shot on the screen! I did this maybe 10-15 times, turned the camera to the side and did a portrait of a backlit visitor sitting half in the darkness. Focus was perfect. The 5D II in compare was surching, surching, surching. It did not confirm. I repeated the test with the man and it was surching and surching and at least confirmed, too. I shot the pic but I can not say if it found the correct focus, because it was a 1/15th shot wide open and I could not hold it (sorry, I forgott to check the ISO setting). The pic done with the 6D was rasorsharp at ISO 25k.
Bron: Fredmiranda
Bron: Fredmiranda
