na lang twijfelen de nieuwste firmware op mijn 300d gezet ging prima
maar..... bij versie staat de zelfde firmawre nummer?
hoe controleer ik nu alle functie's?
dit heb ook de forum gevonden
Volgende "custom functions" zijn bijgekomen:
cf1 SET button func. when shooting - works
0: default / no function (300D default)
1: change quality
2: change parameters
3: menu display
4: image replay
cf2 shutter release w/o cf-card - works
0: possible w/o cf-card (300D default)
1: not possible
cf3 flash sync speed in Av mode - works
0: auto (300D default)
1: 1/200 sec fixed
cf4 shutter button / ae lock button - not sure if it works
0: af/ae lock
1: ae lock/af
2: af/af lock, no ae lock
3: ae/af, no ae lock (300D default? not sure)
cf5 af assist beam/flash firing
0: emits/fires
1: does not emit/fires
2: only ext. flash emits/fires
3: emits/does not fire
cf5 doesn't seem to do anything (maybe only with external flash?)
cf6 exposure level increments
0: 1/2 stop
1: 1/3 stop (300D default)
cf6 seems to be about exposure compensation. seems to work, but the LCD on the back doesn't seem to have the right amount of "ticks" to display this correctly.
cf7 af point registration
(lets you choose different af points, but not sure what that actually does)
cf8 raw + jpg rec
0: raw+small coarse
1: raw+small fine
2: raw+medium coarse
3: raw+medium fine (300D default?)
4: raw+large coarse
5: raw+large fine
didn't test yet - question: will changing the jpg size inside the raw influence C1?
cf9 bracket. sequence/auto cancel - didn't test yet
0: 0,-,+/enable (300D default)
1: 0,-,+/disable
2: -,0,+/enable
3: -,0,+/disable
cf10 superimposed display
0: on
1: off
cf10 doesn't seem to do anything (or I didn't find it)
cf11 menu button display position
0: previous(top if powered off)
1: previous
2: top
cf11 doesn't seem to do anything
cf12 mirror lockup
0: disable (300D default)
1: enable
cf12 doesn't seem to do anything (at least I don't know how to actually trigger the mirror to go up)
cf13 assist button function
0: normal
1: select home position
2: select HP (while pressing)
3: av+/- (af point by qcd)
4: fe lock
cf13 doesn't seem to have any function as there's no assist button
cf14 auto reduction of fill flash - not tested yet
0: enable (300D default)
1: disable
cf15 shutter curtain sync
0: 1st curtain sync
1: 2nd curtain sync
cf15 doesn't seem to do anything, at least with built-in flash. tried a 2sec exposure in M mode, but flash fired at the beginning. af lock didn't help either.
cf16 safety shift in av or tv
0: disable
1: enable
dunno what safety shift is, maybe exposure related?
cf17 lens af stop button function
0: af stop
1: af start
2: ae lock while metering
3: af point: m->auto/auto-ctr.
4: one shot -> <- ai servo
5: IS start
waar vind ik die cf1 tot cf17
is er soms ergens een nederlandstalige versie van de uitleg
waar staan nu al die knopjes
1: change quality
3: menu display
4: image replay
1: not possible
1: 1/200 sec fixed
0: af/ae lock
1: ae lock/af
0: emits/fires
0: 1/2 stop
cf8 raw + jpg rec
0: raw+small coarse
1: raw+small fine
4: raw+large coarse
5: raw+large fine
1: 0,-,+/disable
2: -,0,+/enable
3: -,0,+/disable
0: on
1: off
1: previous
2: top
cf12 mirror lockup
1: enable
0: normal
4: fe lock
1: disable
0: 1st curtain sync
1: 2nd curtain sync
0: disable
1: enable
0: af stop
1: af start
5: IS start
