Nikon d7000
  • Re: Nikon d7000
    Hier een test of indruk , zal toch wel een vet toestel worden denk ik, begin nu toch wel ongeduldig te worden.... van dpreview forum
    Preliminary results - D7000, D700, D300
    This will probably stir up some controversy, but here goes.
    I spent the better part of today testing these 3 cameras. I was somewhat shocked, so I did it again. Same thing. Now we await the REAL scientific tests like dpreview and DXO. Using an ISO 12233 chart as well as a Macbeth Color Checker I came up with the following results. I used the same lens (Nikon 24-70) on all three cameras and adjusted the focal length for the same field of view (no easy task with the D7000 showing 100% in the viewfinder and my D700 only 96%). All shots were done in raw and converted using Nikon ViewNX 2.0.2. (I still am an Adobe Camera Raw fan, but I have to wait). The photos were compared with no sharpening and again with USM at .4 at 100% and 0.
    My findings: The D7000 really needs to be compared carefully with the D700. It pretty much whipped my D300 in every IQ catagory.
    1- The D7000 has better resolution then the D700 (expected) Considerably better (not expected).
    2- The noise level of the D7000 at 3200 was equal to the D700 WHEN BOTH FILES WERE MADE THE SAME SIZE (either by upresing the D700 or down rezing the D7000 in PS CS5. Comparing the two totally different file sizes at 200% gave a 1 stop edge to the D700. But we DON'T print that way. We print a certain size. The same scene printed at 16 x 24 inches would display equal noise from these two different cameras at ISO 3200. Wow. This was a shocker.
    3- Dynamic range is more difficult to measure. First you need two files that have identical levels and curves. This is very difficult to do. Based on my attempting to "stretch" the DR in PS CS5, I would say the D7000 might well have an edge here also. (totally unexpected) This awaits real tests.
    Flame shields up - fire when ready!
    Nikon D810 - Nikon MB-D12 batterijgrip -28mm F 1.8 G - 50 mm F 1.8 G - 85mm F 1.8 G -16-35 F4 -24-120mm f/4G VR -70-200 F4 - 28-300mm VR - SB700
    Nikon V1-FT1 10-30 en 30-100
    • Re: Nikon d7000
      toch iets om zeker uit te proberen..
      • Re: Nikon d7000
        Oorspronkelijk geplaatst door wdwdlp Bekijk bericht
        Hij had blijkbaar een foutje gemaakt
        Steve,
        I think you messed up with the D700's. You had it in Program mode, allowing the aperture to go all the way up to f18, which is causing the mushy performance at ISO3200. You said that all pics were at f8 to control the variables, and they weren't.
        Man, am I embarrassed! A few of you caught my error with the D700 files in my comparison tests. And I THANK you for that. I was juggling three bodies and removing and replacing lens and my eyes failed me. My initial plan was to set all three cameras at aperture priority at f8 - generally a sweet spot for a lot of lenses. Well the D300 was set correctly. The D7000 was set correctly. But I mistook the P for an A on the D700. Funny thing is, I never use P INTENTIONALLY. Sigh. So, I went outside again today and reshot all the D700 shots. Then I came back inside and replaced all the bogus D700 files with correct ones - all at f8.
        Hopefully all is well now. My new (and improved) findings. The D700 produces a good 1/2 to 2/3 stops less noise at ISO 3200. Now that seems realistic.
        The D7000 produced slightly better resolution, especially at the lower ISOs. That makes sense also. http://dustylens.com/d7000_vs_d300_vs_d700.htm
        • Re: Nikon d7000
          De D300 in I.C. weggeblazen op zowat alle gebeid en een zeer close, een halve stop tegenover de D700 is goed genoeg voor mij voor 1049 euro, en daar krijgen we toch nog veel andere extra toeters bij zoals de hd video
          hoop deze volgende week zelf te kunnen testen !!!!!
          • Re: Nikon d7000
            Ik blijf altijd mijn bedenkingen hebben bij zulke testen/geruchten. De tijd staat niet stil maar toch lijkt het mij vrij lastig om deze prestaties te halen. Aan de andere kant als je ziet wat een d3x kan met zo'n hoge hoeveelheid megapixels. Maar zelfs dan nog heeft deze een veel lagere pixeldichtheid.
            Groeten Remco.
            • Re: Nikon d7000
              nikon d7000 - canon 7d
              • Re: Nikon d7000
                Review:
                • Re: Nikon d7000
                  Valt het selecteren van de scherpstellingsmethode een beetje mee in de praktijk ?
