weet er iemand of de kleuren die je af drukt op fotopapier lang kleurvast blijven of hangt het af van printer tot printer indien ja welke is dan een goede printer volgens u
Kijk da is allemaal gemaakt met nen Canon 50D - En wat glas er bij - Cactus trigger en Lowepro Flipside 400 Groetjes,John
Pas op: Dat garanderen ze niet echt. (kunnen ze ook niet trouwens > kan jij 30 jaar in de toekomst kijken van iedere klant die je hebt?)
Dit vond ik op de Canon site:
Precautions on Storing Printed Images: The 25 years of lightfastness may not be achieved depending on storage conditions. The expressed number of years is the result of simulated tests conducted by Canon Inc. and is not guaranteed. This number of years does not apply for paper fading or durability. After printing allow the ink to dry completely. Store your images in albums, clear plastic folders, or glass frames in order to avoid exposing them to the open air. Never store printed images in locations subject to high temperatures, high humidity or direct sunlight. Store them at normal room temperature. (Do not use albums with self-adhesive pages to store your images since you will not be able to remove them later on.) Tested on Photo Paper Pro (PR-101) under the following conditions; Temperature: 24oC, Humidity: 60%, Light source: White fluorescent light 70,000lux, Layer of air and 2mm thick glass on the sample, Presumed conditions: Assuming one day’s illumination as 500lux x 10 hours. In-house Evaluation criteria (Based on ISO)- Single colour/Composite colour: A colour change has occurred if the density is under 70% (OD: 1.0->0.7). Process Black: The fading ratio between each colour is within 15%, and A colour change has occurred if the density is under70% (OD: 1.0->0.7)
uit ervaring weet ik dat navulinkt beter is dan de originele ( van hp ), dit zowel in de zon als waterbestendig !! ( een tevreden hervuller )
