Heb je dat met alle lenzen ebbie of alleen met een lens.
Ooit op dpreview zoiets gezien en dat lag aan een bepaale lens.
Ze hadden er wel een naam voor maar die weet ik helaas niet meer.
Edwin
Hot pixels are individual sensors on the CCD with higher than normal rates of charge leakage. They can appear as small pixel sized bright points of light on longer exposures. Every pixel on the CCD has some charge leakage, and if you expose long enough, any pixel would light up. On a long exposure, you will see pixels ranging from just barely visible to possibly bright hot starlike points. There might be a few bright hot pixels, more intermediate one, and lots of very faint ones, an entire spectrum of brightness. At the low end, the faint hot pixels contribute to the noise in a picture. All cameras on the market today have "hot pixels". Because the rate of charge leakage is the same for a given pixel over time, the longer the exposure, the brighter it becomes. This charge leakage is worse at higher temperatures, even a 10 degree difference can be seen on an exposure. Hot pixels are often just one site, and are one of the colors of the color filter array over that site. In the case of the CP990, hot pixels are usually Cyan Magenta Yellow or Green, although other colors are possible if you have two adjacent hot pixels. Green is the most popular color for hot pixels because there are more Green sensors on the CDD. Most cameras made after 2002 now have a noise reduction technique used on longer exposures that involves taking a duplicate exposure with the lens covered that is then subtracted from the main exposure. Also note that some cameras use software noise reduction that makes hot pixles appear White instead of their normal color (Minolta and Sony do this).
Als je een nieuw toestel koopt, dan kan je na een tijdje er nog krijgen (hot/bad pixel(s))... Das de elektronica hé (ccd/cmos). Heb er op pocket digicams ook al last van gehad, de ene heeft het sneller dan de andere... (geluk?? )
