En hier is die dan.
met 16,7 Mega Pixels, 5fps up to 12 frames, 11/32 RAW/JPG, 0,3s Start, ETTL-II, ISO 50-3200, 4-kleuren histogram, Auto Image Rotation
Gebruikt CompactFlash kaarten en SD kaarten als backup
En met een gewicht van 1.215 gram en afmetingen van 156 x 157.6 x 79.9 mm heeft Canon er weer een nakomeling bij
en hier staan de technische details in het engels.
Specifications
Image Sensor High-sensitivity, high-resolution, large single-plate CMOS sensor
Image size: 35.8 x 23.8 mm (1.4 x 1 in)
Effective pixels: Approx. 16.7 megapixels
Total pixels: Approx. 17.2 megapixels
Lens Mount Canon EF lens mount
LCD monitor/LCD Info 2" TFT color LCD monitor , 100% CoveraGEW with respect to the effective pixels ,
Viewfinder Coverage: Approx. 100 percent vertically and horizontally with respect to the effective pixels
Magnification: 0.7x
Built-In Diopter
Viewfinder information: AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, manual exposure metering range, ISO speed, exposure level, exposure warning), flash information (Flash ready, FP flash, FE lock, flash exposure level) , JPEG formash number of remaining shots, CF card information
Color depth RGB primary colors
Focal lengh multiplier 3:2
Focusing Type TTL-AREA-SIR with a CMOS sensor
45 AF points (Area AF)
Focus Modes One-Shot AF, AI Servo AF, Manual focusing (MF)
Sensitivity (ISO equiv film speed) Equivalent to ISO 100 -1600 in 1/3-stop increments), ISO speed can be expanded to ISO 50 - 3200 with C.Fn 3-1.
White balance Auto, daylight, shade, overcast, tungsten light, fluorescent light, flash, custom, color temperature setting, personal white balance Total 10 settings)
Auto white balance: Hybrid auto white balance with the CMOS sensor and a dedicated, external sensor
Personal white balance: Up to three personal white balance settings can be registered
Color temperature compensation: White balance bracketing: +/3 stops in full-stop increments
Exposure Modes Program AE (shiftable), shutter-priority AE, aperture-priority AE, depth-of-field AE, E-TTLII flash AE, manual, flash metered manual
Exposure Metering E-TTLII full aperture metering with 21-zone SPC
1) Evaluative metering (linkable to any AF point) 2) Partial metering (approx. 8.5% of viewfinder at center) 3) Spot metering
Center spot metering (approx. 2.4% of viewfinder at center),AF point-linked spot metering approx. 2.4% of viewfinder), Multi-spot metering (Max. 8 spot metering entries)
(4) Centerweighted average metering
EV 0-20 (at 20°C with 50mm f/1.4 lens, ISO 100)
Exposure Compensation Auto exposure bracketing (AEB): +/- 3 stops in 1/3 stop increments
Auto Bracketing 1) Shutter speed or aperture (2) ISO speed Manual: +/- 3 stops in 1/3 stop increments (can be combined with AEB)
Shutter type Electronic shutter with the CCD sensor and vertical-travel, local-plane shutter with all speeds electronically-controlled
Shutter Speed 1/8,000 to 30 sec. (1/3 stop increments), bulb, X-synch at 1/250th sec.
Mirror Lock-Up Quick-return half mirror
Diopter Correction -3.0 - +1.0 diopter
Built-In Flash none
External Flash Sync Speedlite EX series E-TTL autoflash
PC terminal Provided; operates regardless of sync polarity
Video Out none
Interface IEEE 1394 (with dedicated cable)
Burst rate Approx. 4 fps buffer 32(JPEG) and 11 (RAW)
Max. burst during continuous shooting: 11 shots
* The maximum shots per burst depends on the subject, shooting mode, and ISO speed.
Video mode none
Audio annotation built-in microphone WAV file Max. 30 sec. per recording to image
Internal Memory/Memory card Type I and II CF card and Secure Digital card for Back-up
Resolution/Images per memory card 1) Large/Fine: approx. 5.5 MByte (4992x3328 pixels)
2) M1 Large/Normal: approx. 3.2 MByte (3600x2400 pixels)
3) M2 Large/Normal: approx. 2.6 MByte (3072x2048 pixels)
4) Small/Fine: approx. 1.9 MByte (2496x1664 pixels)
5) RAW: approx. 14.6 MByte (4992x3328 Pixels)
Image modes Recording format:.Design rule for Camera File system (except Color Matrix 4) and RAW
Image format:JPEG, RAW (12bit), RAW+JPEG simultaneous recording Provided
Self Timer 10-sec. or 2-sec. Delay
Remote Control Remote switch N3-type terminal provided
Depth of Field Preview Enabled with depth-of-field preview button
Power Source One Ni-MH Pack NP-E3 *AC power can be supplied via the AC adapter and DC coupler
backup One CR2025 lithium battery
Dimensions 156 x 157.6 x 79.9 mm / 6.1 x 6.2 x 3.1 in.
Weight 1215 g / 44.6 oz. (body only. battery: 335 g /11.8 oz.)
System requirements Windows 98 SE, 2000, ME, XP; Mac OS 8.6-9.x
Special features 20 Custom Functions with 65 settings and 27 Personal Functions
Specifications
Magnification: 0.7x
Built-In Diopter
Built-In Flash none
Video Out none
Video mode none
