D3X... voorlopig laatste Nikon 24MP toestel?
  • D3X... voorlopig laatste Nikon 24MP toestel?
    Ik vond dit bericht van Thom Hogan redelijk verontrustend. Ik had zoals velen gedacht dat we in de nabije toekomst een 24MP FF sensor in een lager geprijsde D700 body gingen krijgen, maar dan lees ik dit
    Bron: http://bythom.com/
    Sony Sensor Shakeup?
    July 26 (commentary)--I've heard from multiple sources now that Sony Semiconductor is about to drop FX sensors from their lineup. What I'm hearing is that high management in Sony is saying that full-frame cameras and sensors aren't bringing the payback necessary to make them long-term profitable. This is essentially forcing Sony Imaging to consider dropping future plans for full-frame cameras (A850, A900, and follow-ups), though I'm sure we'll still see some FF products from them that were already in progress before the stream of sensors dies out. Some of the sources for the rumor appear to be Sony employees who are lobbying for keeping full-frame in the lineup. They seem to hope that news of the impending decision on the Internet will generate a wave of protest that Sony management can't ignore.
    But this has a Nikon component, too. I've been wondering why I'm not hearing rumblings on a D3xs model (the D3x uses a Sony sensor at its base). It would be due later this year (and I'm on record as predicting it to arrive in December). It very well may be that there's no new sensor for a D3xs (one would have expected video capabilities to be added). Thus, there's almost nothing else of major impact that could be added that would distinguish a D3xs from a D3x. Most of the other proposed additions could simply be firmware updates to the existing model. If we don't get a D3xs by December, we won't get one, as the D4 generation is too close at hand. Thus, it looks highly likely that Nikon's FX future is in their own hands creating their own FX sensors. Given the D3/D700 and D3s sensors, that doesn't sound like a bad thing, but it will put more pressure on Nikon to produce a high-resolution sensor, something they have not yet done (to date, all of Nikon's sensor development has been mostly targeted at low light improvements).
    I think this also answers one persistent question that keeps coming up: "is there any future in DX?" Yes, there is. The reason why Sony would drop FF is rooted in the economics, because the dollar amounts don't really change with sensors like they do with most semiconductor chips. In CPUs, for instance, cost gets driven out by making the CPU chip smaller and using smaller transistors (process size). That doesn't really apply to sensors, as the sensor size itself is not changing, and the light detection mechanism doesn't particularly benefit from smaller transistors (the supporting circuity does). It's just very, very costly to do FF/FX sensors. This puts them into the prosumer and pro categories only, which means there's not a lot of volume. Not having great volume makes it more difficult to reduce costs, and the circle just repeats.
    As I've written before, if an FX sensor costs US$500 then a DX sensor probably costs US$50. And a cellphone sensor these days costs less than US$5 (including lens in many cases). The two ways to get lower sensor costs (other than size) is to increase the wafer size (200mm -> 300mm -> 450mm) or increase the yield somehow. But both of these tend to yield small changes at a time and would produce proportional benefits to each size (e.g., if you could reduce FX costs to US$400, then a DX sensor is going to cost US$40). Moving to smaller process (e.g. going from the current 65 nanometer sizes to 45 or 28 or even smaller) doesn't reduce FX sensor cost. But it might benefit noise handling on smaller sensors. This may be why Sony appears about to concentrate solely on DX-sized sensors at the big end. They may see that they can get to FX-type performance with DX-sized sensors, in which case the cost benefit of doing so is huge.
    So, yes, there's a future in DX. Certainly a Sony future ;~)
    Re: D3X... voorlopig laatste Nikon 24MP toestel?
    Hoort Sony nieuws niet van puerte te komen?
      Alle gekheid op een stokje, als dit waar is zou het geen goed ding worden qua concurrentie.
      Sony was de eerste die goedkope FF's maakte en vroeg of laat zouden de andere merken gewoon
      moeten volgen.
      Ik zag het wel zitten om de 5DIII te zien gereleased worden onder het 2000€ pricepoint
      Have fun!
      EOS 50D - EF-S 18-55 f/4-5.6 IS - Sigma 18-50 EX f/2.8 - EF 70-300 f/4-5.6 IS USM - Sigma 10-20 EX f/4-5.6
        En ik een A950 met de goede Sony live view, degelijke HD-video, een grotere buffer en de fantastische zoeker, voor een 'luttele' € 2000....
        Laten we hopen dat het niet waar is, maar ik meen ook ergens zoiets te hebben gelezen. Ik denk in de Sony Alpha Flickrgroep. Niet alleen Nikongebruikers zijn dus verontrust...
        Ik zou het alleszins erg spijtig vinden .
        Voorbeelden wat je met de D3X en een 400mm f/2.8 kan doen:
          Oorspronkelijk geplaatst door JorisVdB;2749804
          [url
          http://belmaati.zenfolio.com/[/url]
          Dat is ook geen simpele die je hier aanduidt
          Dit is dan ook niet op een-twee-drie gefikst, al is het met D3x
          mvg,
          Roland
            Misschien kunnen ze er een Canon sensor instoppen dan ?
              herinner je je de reden waarom op de eerste cd's ongeveer 74 minuten konden? Dat was omdat mevrouw Philips de 9de van Beethoven wilde beluisteren zonder de plaat om te moeten (laten) draaien.
              Waarschijnlijk vindt mevrouw Sony nu dat haar rimpels te duidelijk in beeld komen ==>exit 24MP sensor.
              The Knight That Says Ni...kon
                Sony kondigt 3 nieuwe FF-lenzen aan :
                En dan stoppen met FF ? Dat zou ik straf vinden
                BD0497BE : Nikon body + glas
                www.RudyVerrijt.info
                  Daar heb je gelijk in - dat zou raar zijn. Maarre, het zijn maar 2 full-framelenzen om precies te zijn. De 35mm DT is iets zoals voor Nikon de Nikkor AF-S 35mm f/1.8 DX - dus niet full-frame compatibel, tenzij in 'crop mode'...
                  Maar zoals je zegt, het zou raar zijn...eerst een hele full-frame line-up wat glas betreft uitbouwen (CZ primes, CZ en G (de professionele serie lenzen van Sony - beetje Canon-L-achtig) zooms, met een paar uitstekende telelenzen...). Ik hoop dat die Thom Hogan ernaast zit! Want stiekem hoop ik toch op de A900-opvolger met dezelfde reusachtige zoeker, nog betere hoge ISO-prestaties en de unieke live view en de HD-video...en hetzelfde voor jullie Nikongebruikers, natuurlijk .
                  Sony verdient toch ook aardig aan deze sensorproductie, neem ik aan ?!
                    Wie weet wat er zich allemaal afspeelt in die japanse achtertuin Ik hoop ook dat het helemaal niet waar is, want dat gaan we veel geld blijven betalen voor minder snel evoluerende FF toestellen...
                    Thom heeft vandaag nog wat nieuwe commentaar gegeven: http://bythom.com/
                      Jullie geloven toch nooit dat ze Canon lekker verder alleen FF sensoren zullen laten verder maken , daar geloof ik helemaal niet in, op die manier zouden Sony en Nikon alleen maar marktaandeel verliezen, die markt voor hoge resolutie FF is heus groter dan je denkt en terecht.
                        Oorspronkelijk geplaatst door RDB Bekijk bericht
                        Ik vind het toch wel vreemd dat er bij Nikon met geen woord gerept wordt over een 5D2 concurrent. Eerst werd die in het begin van dit jaar verwacht, en nu hoor je er al maanden niks meer over Er wordt enkel over een D700s gepraat met de sensor uit de D3s zodat de D4 de FF sensor van de volgende generatie uit eigen stal gaat krijgen (16-18MP?) Misschien legt een D90 opvolger veranderde samenwerkingsverbanden tussen Sony en Nikon beter bloot?
                          Ik had ergens gelezen over mogelijke aankondigingen rond 20 augustus.
                          Maar het zal vooral wachten zijn en thee drinken
                            Oorspronkelijk geplaatst door JePe Bekijk bericht
                            En ook lekker blijven verder werken met het huidige materiaal dat nu al zeer indrukwekkende prestaties levert tov dat van 6 jaar geleden
