Sony Alpha A200 AF points
  • Sony Alpha A200 AF points
    Hi All,
    I searched a lot for the things i need and want to know.
    There a some issues with the Sony DSLR compares with the Canon's.
    When I Shoot with my old EOS 10D, I can chose to set my Auto focus points.
    I can chose one point AF, or all points.
    I bought an A200 to see if I do like the camera.
    And I Do, i really love the Sony Alpha camera's.
    The issue I have, when I shoot with the EOS the Auto Focus points are glowing red, when the camera is using more then one point, two or more points are glowing red.
    When I shoot with my Sony Alpha, I get only one red glow in every modes.
    It uses the cross point Auto Focus, but it is using just one point every time.
    I wonder, is it using more then one point, but only one is glowing red? or does it just uses the point that's glowing red.
    I tried more options, Wide, Spot, and Local.
    Wide should use every point, Spot is center Af, and Local you can set the right point.
    Does Sony only use one point at the time? or is it that only one point is glowing?
    I'm using a Minolta 28-75 F2.8.
    But I also have this issue with my 70-300 Tele lenses.
    Thanks.
    p.s. Reageer maar gewoon in het Nederlands
    Re: Sony Alpha A200 AF points
    Bij mijn weten gebruikt de A200 inderdaad maar 1 AF punt, ik werk altijd in de modus 'lokaal' waar ik het scherptstelpunt zelf kan kiezen.
    Vanwaar het engels trouwens?
    about.me/stijnv
      Oorspronkelijk geplaatst door AlexMeijer Bekijk bericht
      Correct
      Ik vind dit trouwens een voordeel om duidelijk te zien waar precies de camera scherpstelt. Het wil natuurlijk niet zeggen omdat 1 punt oplicht, dat er niets anders (binnen hetzelfde vlak) ook scherp is
      You`ll get used to it
        Oorspronkelijk geplaatst door Stijn.V Bekijk bericht
        Om deze reden
        Flickr____No place to be
          I have the A300, and when it is on "wide", sometimes several points glow up.
          It is of course easier if you focus on objects which are not too close and parallell to the camera.
