lees dan gewoon de conclusion en de pro's en de con's op de laatste pagina van die review...
Conclusion - Pros
* Compact and lightweight digital SLR which is comfortable despite the lack of grip
* Good image quality and resolution if not optimum straight out of the box
* Low noise across the ISO range by default, turning down noise filter doesn't spoil images
* Through the lens Live View with Auto Focus (although requires mirror up/down)
* Up to ten times magnification in Live View for manual focus
* Supersonic Wave Filter ensures no dust on sensor
* Responsive in use, auto focus fairly quick, shutter lag short
* Good quality lightweight kit lens makes for lightweight 'carry around' kit
* User control over ISO noise reduction ('Noise Filter')
* More customizable / feature rich than competition
* Black and white mode with selectable filters
* Kelvin white balance option, all white balance presets fine tunable
* Selectable color space (sRGB / Adobe RGB)
* Fully customizable RAW+JPEG (many competitors have fixed JPEG settings)
* Spot metering with shadow and highlight based spot
* Timed long exposures up to sixty seconds
* Effective long exposure noise reduction ('dark frame subtraction')
* Mirror lock-up with custom delay
* Unlimited continuous shooting on fast card with HQ quality JPEG
* Good Compact Flash write performance, up to 7 MB/sec with a fast card
* Good range of playback options / views
* In-camera RAW development feature
* In-camera JPEG image editing
* Easy, automatic online firmware upgrades (via Olympus Master / Studio)
* High speed USB 2.0
* Orientation sensor
* Value for money
Conclusion - Cons
* Dynamic Range less than competition (highlights by about three quarters of a stop; 0.7 EV)
* Small viewfinder (difficult to see fine detail, difficult to check focus)
* Live View usefulness countered by LCD which doesn't tilt, not bright enough outdoors
* Maximum sensitivity actually ISO 1250 not ISO 1600 as indicated
* Battery life seemed shorter than we would like (thanks to small battery, regular LCD use)
* Best results require adjustment of Noise Filter and Sharpness settings
* Slower than average startup due to the SSWF (should be at power-off / intervals)
* No delete / cancel option during record review (immediately after shutter release)
* Auto focus provides just three focus points, although AF performance good
* Focus-by-wire kit lens means no focus distance indication
* Flash must be raised for AF assist
Om eerlijk te zijn: de E410 is de camera die ik altijd voorstel binnen mijn vriendenkring. Om eerlijk te zijn: ik vind er weinig nadelen aan...
Handligging kan een probleem zijn (al is dat persoonsgebonden.) Voor de rest een prima toestel dat vrij populair is. Het voordeel is dat je er twee vrij goede lenzen bij krijgt (beter althans dan de kitlenzen bij de concurrentie.)
