Nikon D200 firmware... 2.0.0 (UPDATE 02/10/06)
  • Nikon D200 firmware... 2.0.0 (UPDATE 02/10/06)
    Issues addressed with firmware version 2.0.0
    1. Image authentication item has been added to the setup menu. The optional Image Authentication software is required to authenticate images.
    2. A Wireless transmitter item has been added to the setup menu. This item is available only when the optional Wireless Transmitter WT-3 is connected to the camera.
    3. For more information download the supplemental manual d200-fudm.pdf. Acrobat Reader must be installed on your computer to view this file.
    -> UPDATE; Sigma lenses that should be rechipped because the AF/MF, should work now !!!!
    The basic steps to update the firmware are:
    1. Download and expand the firmware files
    2. Format an approved CF card in the camera (do not use a Microdrive card to perform this update)
    3. Connect Camera to computer (in MSC USB mode) or use a CF Card Reader (do not use a Lexar Jump Shot USB cable to perform this update)
    4. Copy to the top level of the card the downloaded "A firmware" file
    5. Disconnect camera from computer
    6. Update the firmware from the "Setup" menu
    7. Follow the camera's on-screen menus
    8. Repeat steps 2 through 7 using the "B Firmware"
    9. Re-format Card
    http://support.nikontech.com/cgi-bin...i=&p_topview=1
    Lesley.
    -=- Light is the key...
    Re: Nikon D200 firmware... 2.0.0
    Het is maar de vraag of deze update echt nuttig is...
    ...but I could be wrong...
      Ik zat het ook juist te denken. Ik haast mij nooit met updates, soms zitten er nog kleine kinderziektes in.
        Oorspronkelijk geplaatst door vantje Bekijk bericht
        Van 't zelfde gedacht hier
        fotosite
          En ik hoor het wel weer van jullie
          Van alles...
            Geldt hier ook niet: 'Don't fix, what ain't broken'?
              ...or "never change a winning team"
              Van alles...
                en ik denk dan van..... ik zal nog eens iets posten...
                wat is dat hier tegenwoordig...??
                (er zijn er altijd die de wireless transmitter gebruiken etc... Niet iedereen gebruikt alles!!!!!!!!)
                  Vogende week heb ik een lezing over highspeed fotografie, daarna zal ik de camera upgraden naar de nieuwe versie om alle mogelijkheden te kunnen benutten.
                  Ik ben voorstander van een up-to-date software.
                  De nieuwe software staat al klaar op de computer.
                  Frans.
                    Oorspronkelijk geplaatst door de.lesse.be Bekijk bericht
                    Vanwaar zo'n reactie ???
                    Als iemand beslist van de kat uit de boom te kijken of zelfs helemaal niks up te graden, da's toch zijn eigen keuze, of niet ? En mag dat dan niet gezegd ??
                    fotosite
                      Dit begrijp ik ook niet helemaal eerlijk gezegd
                      Van alles...
                        Ikzelf zal de update waarschijnlijk wel doorvoeren, al is het maar om de meest recente firmware geïnstalleerd te hebben op mijn camera.
                        Maar het moet gezegd worden... de meeste D200-bezitters, mezelf inbegrepen, zullen waarschijnlijk weinig of niets hebben aan de nieuwe opties...
                          /MOD OFF
                          Tof dat een Canon gebruiker hier de laatste info post over Nikon
                          En troost je, je zult altijd wel mensen tegenkomen die je voorstel of uitleg in twijfel trekken.
                          Laten links liggen en gewoon doorgaan, ondertussen zijn toch weer enkele D200 gebruikers geholpen .
                          Groeten,
                          Ludo
                            Mag ik mij verbazen over deze merkwaardige stellingname door een moderator ?
                            TS start een topic waarop reactie komt van enkele Nikon D200 gebruikers, waaronder mezelf, die zeggen niet direct hiervan gebruik te durven/willen maken.
                            Hierop geeft TS een nogal scherpe reactie met drie "thumbs down".
                            Nu lees ik hier tot mijn verbazing dat hij wordt bijgevallen door een moderator in functie
                            Het is niet mijn gewoonte mij te moeien met de forumrichtlijnen maar ik vind dit niet kunnen, sorry.
                            fotosite
                              Seg dit is geen drama he...
                              In de tijd van Julius Ceasar...als die zijn duim omlaag deed
                              was het definitief gedaan he
                              Probeer eens ne mens een beetje te begrijpen....
                              Die jong post hier iets waarvan hij denkt (denk ik toch)
                              dat er velen blij mee zullen zijn....
                              En het is toch ook eens leuk als je als eerste met een bepaalde post
                              komt...
                              Doe zoals vriend Corné gisteren zei:
                              En nu terug fotograferen!
                              Opa heeft weer eens gesproken
                              Dit geheel terzijde omdat ik off-topic ben.
                              En om het in de taal van "Juul Sesaar" te zeggen:
                              "Sit venia vobis"...
                              Ubi bene, ibi patria.
                              BD0388BE
                              Een website
