Skyport
  • Skyport
    kan iemand mij uitleggen wat het verschil is tussen:
    dit
    en
    dit?
    prijs is dezelfde...
    welke zou het zou zijn om een RX 600 / 600 van elinchrom aan te sturen?
    Alvast bedankt!
    5DmkII | EF 24-70 f2.8 L |EF 70-200 f2.8 L IS USM II | strobist stuff | www.dvbphotography.be
    Re: Skyport
    2e is de nieuwe versie de zogenaamde "speed"
    De eerste versie had soms wat problemen boven de 1/125, met de speedversie zou je hoger kunnen (1/250).
    What's NEW... EL-Skyport SPEED - Added Values
    LED status for EL-Skyport sync mode and battery status.
    Improved housing, battery drawer and switches.
    Improved integrated Hot-shoe with screw lock.
    Improved SYNC-socket for direct connection.
    NORMAL & SPEED Sync modes, please read below..
    NEW... Two synchronisation modes, STANDARD and SPEED
    The “Standard” mode is fully compatible with previous EL-Skyport versions.
    The SPEED function is available for Ranger Quadra AS, BXRi 250 / 500 und D-Lite-it and all other units, when used with the Universal Speed.
    Up to 60 m range indoors for STANDARD mode and up to 40 m in SPEED mode.
    Up to 120 m range outdoors for STANDARD mode and up to 60 m in SPEED mode.
    Up to 1/150s shutter speed for SLR cameras in NORMAL mode.
    Up to 1/250s shutter speed for SLR cameras in SPEED mode.
