lowepro commercial / magnum
  • lowepro commercial / magnum
    Has anyone used both of these bags and can judge the capacity?
    I've seen a Magnum but not seen a Commercial AW yet.
    They have to be able to hold 2 large bodies + the usual assortment of fast lenses. Of course, most of those are 77mm diameter so when someone says "5 lenses fit" that's normally 4 fat lenses..
    Ideally, I leave both bodies with lenses attached, the rest need to be quickly accessed of course. Again, some bags seem to fit 2 pro bodies but only if the lenses are removed first.
    At the moment I'm using a backpack, handy, but not ideal for a lot of jobs, plus.. it's too small already
    Of course, weight is an issue too, my back is pretty useless as it is, so whatever I get, it's going to be moved around on a roller system as much as possible.
    Thanks, Rob.
