Verschil Lowe Pro Orion Trekker en Orion Trekker II
  • Verschil Lowe Pro Orion Trekker en Orion Trekker II
    Wie kan mij het verschil uitleggen tussen deze twee tassen? Min andere kleurtjes zie ik zo 1 2 3 geen verschil (heb ze nog niet in real-life gezien). De Orion Trekker II is ongeveer 20 euro duurder. Maar wat is er verder nog anders aan en is het het verschil waard?
    Re: Verschil Lowe Pro Orion Trekker en Orion Trekker II
    De Trekker II blijkt een geupgrade versie te zijn met nieuw design en met wat aanpassingen voor digitaal (voor geheugenkaartjes vermoedelijk). Meer details kan ik ook niet vinden. De oudere versie zal gewoon einde-reeks zijn en daardoor wat goedkoper.
    ps: ik heb de oudere versie naast mij staan,vraag maar...
    edit:
    Lowepro Orion Trekker II introduction : Lowepro, the worldwide leader of protective cases and backpacks for imaging products, is giving a sporty new look to its line of backpacks for active and outdoor photographers. The new Lowepro Orion Trekker II includes a colourful and stylish exterior while providing users with the freedom and flexibility to customize the two-compartment backpack based on the assignment and location. The new Lowepro Trekker II's two distinct compartments, a well-padded, removable lower camera compartment for storing an SLR camera (digital or analogue) with an attached lens, several additional lenses, a flash unit, compact binoculars and accessories, and an upper compartment for safely housing other products.
    Unique to the Lowepro Orion Trekker II is its built-in pocket for an MP3 player, Mini Disk or CD player. A specially designed discrete earphone pass-through cable port allows music to be listened to while the audio player remains secure within the backpack's designated compartment and keeps cords and cables safely tucked away for hands free listening.
    "The new Lowepro Trekker II provides photographers with a level of versatility not found with other camera backpacks," says Suzanne Caballero, Marketing Communications Manager at Lowepro. "Its unique and fashionable design, along with its bright color scheme, add an element of style to the backpack while appealing to today’s digital photographers," added Ms. Caballero.
    The new Lowepro Orion Trekker II backpack provides a number of features which have made Lowepro a leading manufacturer in the photographic industry and the preferred brand among photographers for more than 35 years.
    Additional features include a removable waist belt, several SlipLock attachment tabs for additional pouches, lens cases and other desired accessories, a 3-point shoulder harness system for greater comfort and even weight distribution for better balance; a breathable mesh back panel for greater comfort; five nylon padded insert dividers for easy storage and quick access to camera accessories; and a number of electronics accessory pockets for storing batteries, memory cards or cords.
      OK, dus min een paar kleine extratjes zijn er niet hele grote veranderingen. Omdat ik die extratjes toch niet ga gebruiken denk ik dat ik toch maar voor de oude ga, vind deze persoonlijk ook iets mooier (compleet zwart). Denken jullie dat hierin een Nikon D50, sigma 18-50 en een sigma 70-300 past? Al dan op de body gemonteerd?
      Thanks!
        Oorspronkelijk geplaatst door jessehos
        Thanks!
        dat moet net lukken
        Greetz
        Sam Jae
          Zal geen probleem zijn om dat in het onderste compartiment te krijgen.
          Ik stop er mijn 10D + batterygrip + objectief in, samen met een los objectief en de bijhorende zonnekappen.
          Dan heb ik eventueel nog plaats voor een paar filters of de lader met stroomkabel. Ik heb wel de orion trekker II, maar veel verschil qua grootte zal daar niet op zitten. Zéér handige rugzak trouwens, bovenin kan je nog vanalles kwijt.
            Thanks!
            IK heb ook een oudere versie, ben er heel tevreden van...
            Onderaan zit mijn 20D met 28-135 IS ums op, en er steekt onderaan nog een 19-35 bij (destijds stak er nog een 50mm 1.8 bij). De 135-400 bewaar ik in het bovenste gedeelte. Destijds had ik ook een sigma 70-300apo en die bewaarde ik ook bovenaan omdat ik deze in zijn hoesje bewaarde, maar als je hem daaruit neemt, kan deze van hoogte er juist in.
